Deploy Thingworx 9.1 in Azure App Service
MM_8892976
7-Bedrock
I have been trying to deploy the Thingworx docker in Azure App service but the container Terminates. As the Azure app service does not support docker-compose I am using the single docker to deploy. There are no logs available as well as there is no way to specify the properties.
Has anybody who has deployed Thingworx on Azure App service.
5 REPLIES 5
@MM_8892976
Please refer following community post , if it matches your use case.
Sachin
Thanks for the response. But my requirement is to deploy on Azure App service only.
HI,
See if this helps.
Regards
Shyam
Thanks for the response but my requirement is to run it on Azure App service only.
As a first step I would verify that the image runs in docker desktop.  If it does, then you can be reasonably certain that the image is sound.  If not, you should be able to access the logs and fault-find.  It would help to map volumes so that you can access all the logs.
If the image runs fine on Docker Desktop you may need to follow a tutorial such as : https://docs.microsoft.com/en-us/learn/modules/deploy-run-container-app-service/
Hope this helps.
