I am using ThingWorx Platform Release 9.2 and DatecodeSP6
Trying to Be Deploying Thingworx.war file in Localhost8080, but it's just loading and stopping the Apache Tomcat Services, Once the Tomcat Services got Stop the Localhost8080 Page showing error that it cannot be loaded. Would be please Schedule a Call. We are installing the version 9.2.6
1) The product is called ThingWorx, not Thongworm. You either misspelled or you are in the wrong place.
2) Please understand this is NOT PTC support. This is a public forum, no-one here will schedule a call with you.
If you need product support, log a ticket with official PTC support at support.ptc.com
3) There is no need to post several times about the same topic. You already opened a thread under https://community.ptc.com/t5/ThingWorx-Developers/http-localhost-8080-its-not-Connecting-and-when-is-open-first/td-p/1035223/jump-to/first-unread-message and you got replies there.
When I am deploying thingworx.war file, the services got start and immediately get stop and localhost8080 is showing popup that its cannot be loaded. I can see the thingworx folder but some of the files are not install and in thingworx platform licence key is not generated.
Hi @JJ_10299656
You're deploying such an old version and there are numerous things that may be contributing to your issues:
- Incompatibility with the o/s, database, Tomcat, or Java that you have installed
- Failure to run the scripts for creating the database schema and tables
- Configuration errors
There are so many things to review here, it would be best to open a case. If you like to move forward with a case, I'm happy to open one on your behalf.
--Sharon
Hi @JJ_10299656
Just checking to see if you've made any progress on your issue. If not, we're happy to help.
--Sharon
