I have made a simple workflow and validate it.But It is not showing in Workflow Management.Can anyone explain how to correctly make a workflow and suggest some tutorial for thingworx utilities ?
Workflow Management does not display Workflow definitions (the Workflows you are building). It allows you to view Workflow instances which are initiated when the Alert/Event that was configured for the Start nodes of their associated Workflow definition are triggered. The Workflow definition that you created in Workflow Builder can be seen when you click the 'Open' button in Workflow Builder.
