Hi Team,
Is it possible to show tree structure in tree grid advanced widget just like normal tree widget?
Because tree grid advanced widget displays data in the form of grid.
If yes, then please share the solution.
Hi @ranjank
Yes, it is possible to show tree structure in tree grid advanced widget. For the solution, could you refer the following link to ThingWorx Help Center? It includes the sample mashups as Advanced Grids Samples File and you can find tree grid advanced widget sample in "Hierarchical Parts List Example From Dynamically Generated Data" mashup.
ThingWorx Help Center: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FMashup_Builder%2FWidgets%2FWorkingWithTreeGridData.html%23
Hi @ranjank
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Toolika Dixit
