Displaying my infotable on a mashup
GV_11098078
6-Contributor
I have a infotable in my things project, under properties and alerts, i want to display my infotable in a grid in a mashup, is that possible or only if i have a data shape?
Hi @GV_11098078 ,
Yes it is possible to display the infotable property value in mashup. In your service you can the blow code to get property values as Infotable Output.
result = Things["YOURTHINGNAME"].YOURINFOTABLEPROPERTYNAME;
Thanks & Regards,
Arun C
3 REPLIES 3
Hi @GV_11098078 ,
Thanks & Regards,
Arun C
Hi @GV_11098078,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
For future reference, it's impossible not to already have a DataShape set for an Infotable if it's defined in the Properties section, so in your situation you already have a Data Shape defined.
There's a builtin service called GetPropertyValues that gets you the value of all properties in the Thing - if you need just one property and don't want to transfer the others to the browser, then yes, a custom service like the one suggested by @Arun_C  is needed.
Note: if the infotable is the output of a service, what I wrote above is not true - it does not need to have a Data Shape defined, and you need to set it manually in the service's output section.
