Document from Windchill is not visible in Navigate
Level 7
Hello Everyone,
I have setup PTC Navigate, However I am unable to see the document from Windchill and getting the attached as an ouptut.
x
Thanks in advance.
John D.
Tags (1)
Re: Document from Windchill is not visible in Navigate
Hi John,
What version of Navigate are you on? This looks like a known issue with Navigate. If this article doesnt work or you need additional help, it would need Support Services to investigate. A case can be logged with TS here.
Bibek
