Hi, I work for an FDA regulated company that requires a stringent documentation process of code. Is there a best practice or strategy for using the 'documentation' section of each entity?
Hi Thomas,
I don't think so.
The options you have to documentate code:
Just one last perk, when you save an entity on the composer if you click on the button next to Save you can write a comment on what's modified.
As you can see TW it's well designed to documentate everything, where it fails it's then if you want to generate a "printable" version of everything you had write on previous parts. But you can enter on "Server" view and see everything you documented: "yourServer"/Thingworx/Server
Hi, Thomas.
I'm not sure that we have specific documentation that calls this out. Let me see what advice I can get for you here.
-- Craig A.
Hi Thomas,
I don't think so.
This is helpful, thank you!
