Where can i find a proper documents, having explanations for all the snippets used while writing services in a Thing.
Am new to thingworx programming and i get stuck in simple problems like converting an array into infotable.
Its hard to know which snippet is for what task, and how to use them .
There is no official documentation on Snippets.
You can take a look here: https://community.ptc.com/t5/IoT-Tech-Tips/Unofficial-ThingWorx-Snippet-Enhanced-Documentation/td-p/642808
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
