Can we pull the data and store it in thingworx to reduce the DB calls/clicks.
It depends on your use case. You can store and retrieve data from in-memory objects like infotable. Or else you can use session parameters to store and retrieve information that is nonpersistent(not a DB call basically). Except this there is no OOTB cache mechanism in ThingWorx, however, you can achieve this using the above methods considering your use case.
Hi @Nelluri_Pranay
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
