Hi everyone,
I'm a beginner and I'm a starting on vudoria studio. At a moment of the tutorial i need to access to Thingworx Composer using my server url which work. Then I need to create an application Key and a thing who doesn't work. I have the same issue wich is below:
How can I resolve this problem?
Thank you in advance for your answers!
It's seems its because I have a free trial count.
So how get around this problem?
Hi @yanis.
You can reach out to our Sales team to discuss options around licensing. Be sure to explain that you are currently running a Vuforia trial but need to be able to access Composer.
Regards.
try providing collection permissions at entity levels ( Thing, ThingTemplate , Shapes etc) for that user
I will try @rosharma but I'm not sure if I will succeed but thanks anyway! :)
Hi @yanis.
Do you have an update on this issue that you can share with the community? If you have found a solution, we would love for you to post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
