Download TimeSeries chart as a picture
SaranKarthick
Hi Developers,
I have developed a mashup which has a time series chart showing data (image attached). The requirement is to get this chart/mashup in a pdf file. Is there any default widgets to achieve this functionality.
Thanks and Regards,
Saran
1 ACCEPTED SOLUTION
You have to create the server address and map it to the createPDF service parameters on the mashup .Even i found one more post related to your query which directly print out the current mashup on button click
Go through this post and see if this can solve out your use case --
https://community.ptc.com/t5/ThingWorx-Developers/PrintButton-Extension-project/m-p/532671
Mukul Narang
7 REPLIES 7
There is a PDF Extension on MarketPlace - https://marketplace.ptc.com/apps/193615/pdf-extension#!overview
You can download this extension and import in in Thingworx .After importing it will bring a resource called PDFExport and under this you will get a service called createPDF .Using this service you can take a snapshot of any mashup as a PDF file .
Thanks ,
Mukul Narang
Hi @mnarang,
Thanks for your response.
I have tried the service and a pdf is getting created but it seems to be blank.
Saran
Can you put on the screenshot of createPDF service arguments ? Just ensure you are passing correct App Key and what is the value that you are passing in server address ?
Hi @mnarang,
Sorry for the late response. I had tried the service once again and this time it worked as expected.
1. For the Server Address i have given the below:
"https://<IP Address>/Thingworx/Runtime/index.html#master=<MasterName>&mashup=<MashupName>"
2. To create App key i had used Administrator role.
There might be a chance if i had used an app key with a user whom doesn't have access to the mashup would get a blank pdf
So in a practical scenario if the user want to get the pdf in runtime at the press of a button, how would i get the Server Address ( the mashup URL which has to be dynamic since the user might want to get pdf of any screen of interest) ?
Thanks and Regards,
Saran
@mnarang
Could you please have a look on this.
Mukul Narang
Hi @mnarang and @mgoel,
Thanks for your suggestions. I had followed the link and was able to download the chart as a pdf.
Saran
