You may try developing a custom extension similar to the PDF one in the marketplace to capture the details you need. Attached is the documentation on custom extensibility.
Hi @TanmeyTWX
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the @posipova answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
