Has anybody implemented some type of drill down capabilities using the TWX charts?
something like: http://www.highcharts.com/demo/column-drilldown
Cheers
Ewerton
Not as nice, but with standard Graphs and Contained Mashups you may get the "same" effect.
Thanks Carles,
I thought about it. Will start exploring.
Cheers
Ewerton
Hi Carles,
Is not possible to incorporate customized charts (widgets) based on javascript? If that is feasible then highcharts.js, d3.js and others can be used within Thingworx. Any idea how to do that?
Juan
Yes it's totally possible.
Look at ThingWorx extensibility options.
The best starting point ( after reading some documentation ) would be downloading this Extension from the Marketplace and playing modifying it : https://marketplace.thingworx.com/Items/Custom%20Chart%20Widgets
Carles.
