Dropdown Color
NP_10149671
8-Gravel
Dropdown Color
Hey @krishnakomal ,
Do you know how to change the color of dropdown scrollbar by using CSS? Here I attach SS.
Please help me in this.
Thanks.
7 REPLIES 7
You can maybe try :
body {
  scrollbar-color: red yellow;
It'll probably modify all scrollbar
To only modify the scrollbar into the dropdown you can maybe do :
.YOUR_DROPDOWN {
  overflow-y: scroll; /* I think you already got this */
  scrollbar-color: yellow green;
Hi @LM_10415801 , @bchaudhary ,
It's not working. Please check attached Screenshot.
Thanks.
Hello again @NP_10149671 ,
Instead of "YOUR_DROPDOWN" you have to write the name of the dropdown (in css, after "." you have to write the name of the component you want to design and after "#" you have to write his id).
Best regards,
Hey @LM_10415801 ,
 After "." I wrote the name of the component and after "#" I wrote color id. But still it's not working. Shall I need to add anything in this (Please check SS.)
Thanks.
Hello @NP_10149671 ,
Pls check the below attached community post. And it happened to solve the similar issue.
Let me know if it helps.
Bhawna
Hello @NP_10149671
My bad I haven't attached the post Please check the below post and let me know if it resolve your issue.https://community.ptc.com/t5/ThingWorx-Developers/I-want-to-change-the-scrollbar-style/td-p/788917?posno=13&q=change%20the%20color%20of%20scroll%20bar&source=search
Hi @bchaudhary ,
Previously, I gone through this post and checked but it did not work.
Thanks.
