I am using List widget in the Dropdown view type. The problem is all the list items and selected item gets truncated. I have tried List Format property to fix this issue but unable to do so.
Currently I am using version 8.2 of ThingWorx.
Thank you.
There is one more setting called WidthOfDropdownView right below View, increase the numbers of pixels to match.
