I installed EMS, and it successfully connected to the Platform.
However, when I create an SSH tunnel to the EMS with Remote Access Widget,
connection fails with following messages.
1. When I click on the Remote Access Widget, WSEMS log shows
TUNNEL NOTIFICATION:
ThingName: TestThing
State: STARTED
Target: 127.0.0.1:22
StartTime: 2016-11-22 09:15:31,976
EndTime: Still in Progress
Duration: 0 msec
User: Unknown
Bytes Sent: 0
Bytes Rcvd: 0
Message:
2. But after some seconds or minutes,
State: ENDED
StartTime: 2016-11-22 09:14:36,793
EndTime: 2016-11-22 09:16:07,464
Duration: 90671 msec
User: Administrator
Bytes Sent: 41
Bytes Rcvd: 0
Message: An unrecoverable IOException occurred so the connection was closed
When I attempt to connect via localhost:16345 with TeraTerm, username/password prompt appears.
But I can never complete login because End of Tunnel occurs before/at the same time as pressing OK button on the TeraTerm's login prompt.
Does anyone have idea?
Edge
Raspberry Pi 3
WSEMS Version5.3.1 (Linux-ARM-HWFPU)
Platform
ThingWorx 7.0.1
Network
Wifi Router (no proxy, can establish SSH connection via 22 port directly)
Shunsuke Yamabe
Now we have just solved this problem by ourselves.
We should check "AcceptSelfSignedCert" as we use self signed certification.
As I checked this configuration, I could successfully establish the SSH session.
