EMS: Which protocols can be tunneled?
Highlighted
Aquamarine
I establish a ssh connection without problems. RDP works sometime but not on my PC. Thrid I need to tunnel an webserver (port 80 or in special case 4444).
which protocols can be tunneled via EMS with Thingworx Remote Access Client?
1 REPLY 1
Re: EMS: Which protocols can be tunneled?
First of all my knowledge on this is probably 2-3 years old but originally, the EMS tunnel capability provides a single TCP/IP end point.
What have I seen working with that is ssh and RDP as well as some connections where you can point a Client to a Server like RS Linx to an RS PLC or Siemens Simatic Step 7 client connection to Siemens PLC
I've heard of use cases where somehow even connections were possible where two end points were needed, not sure though where to find that info.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
