EMS and Tunneling - Tunnel Subsytem is not running.
A_Macierzynski
Hello all!
I am struggling with the EMS configuration on the Customer side, especially Tunneling.
  • ThingWorx 8.0.7-b74 HTTPS
  • EMS 5.4.0 OPENSSL Windows x86-x64
Configuration file:
    "ws_servers":   [{
            "host": "###",
            "port": 443
    "ws_connection": {
        "encryption": "ssl"
    "logger": {
        "level": "DEBUG"
    "appKey":   "###",
    "certificates": {
        "validate": false,
        "allow_self_signed": true
    "http_server" : {
        "use_default_certificate" : true,
        "ssl" : false,
        "authenticate" : false
    "auto_bind": [{
        "name": "DemoThing123"
It seems to be standard dev configuration. No issue with my local instance (HTTP).
The problem is if I want to connect and establish tunneling on the Customer instance.
First of all Tunneling seems to be not working correctly at all:
RemoteThing (with tunneling ofc) is connected. Tunneling is enabled and created. (tcp, 5900, vnc)
In the mashup I am receiving:
TunnelingSubsytem is Enabled, Running. Nothing weird.
NOTE: One thing is that in Configuration of Tunnel Subsystem there is a host defined, which I cannot ping. (IP is different than IP of this instance). I am not an Administrator user, so cannot change it.
Any ideas?
Best Regards,
Adam
0 REPLIES 0
