EMS5.3.2(wsems.exe and Lua) thingworx.server.setProperties/setPropery functions used but had errors
knishimatsu
3-Visitor
Hello all.
now we are developping new remoteThings with EMS5.3.2(using wsems.exe and Luascriptresource.exe).
Then we have two serious problems.
No.1)
we sent one property value,and we verified this value received server.
However the wsems.exe is displayed message as below.
[ERROR] 2016-08-27 17:45:32,168 SDK: twInfoTable_ToJson: NULL of bad infotable
we sent property using by thingworx.server.setpropery function.
we read the LuaDoc that included with the EMS5.3.2_archives.
Why the wsems.exedisplayed ERROR message ?
We used testing template.lua as follows.
-------------template.lua----------------------------------
module ("templates.example", thingworx.template.extend)
local params = {}
params = {
    ThingName = me.name,
    ThingTemplate = "TEST_TEMPLATE",
    Tag = "Sentinel",
    Tag_Term = "Sentinel_Service",
    Description = "EMS specifications check"
thingworx.server.invoke("CreateThing", params, "create_RemoteThings")
local rtncode
local rtnresp
local prpsend = {}
prpsend["member1"] = "Su-Metal"
prpsend["time"] = os.time() * 1000
prpsend["quality"] = "GOOD"
rtncode,rtnresp =  thingworx.server.setProperty("member1", prpsend, p_data.name)
-------------template.lua end----------------------------
No.2)
we sent some properties values using thingworx.server.setPropeties function.
But Server is not received all values.
And Server Application log has errors as below.
----------- server Application logs ---------------------
2016-08-27 18:08:15.937 ERROR An Invalid Property Value Was Sent To [EXAMPLE_TEST Property: [null] Administrator c.t.t.c.RemoteThing WSExecutionProcessor-10
In the case,wsems.exe & luaScriptResurce.exe does not output an Error
-------------template2.lua----------------------------------
local params = {}
params = {
    Tag = "Sentinel",
local rtncode
local rtnresp
local prpsend = {
                  { name = "member1",value="name1",time=os.time()*1000,quality="GOOD" },
                  { name = "member2",value="name2",time=os.time()*1000,quality="GOOD" },
                  { name = "member3",value="name3",time=os.time()*1000,quality="GOOD" }
rtncode,rtnresp = thingworx.server.setProperties(prpsend, p_data.name)
-------------template2.lua end----------------------------
We are for the first time to build the EMS with wsems and Lua.
So, we still lack understanding.
Please let us know if you have some advise and question.
Sincerely
Kenichi, regarding the first issue, we have an internal ticket for the same. I'll let you know (and update this thread) once I have more information.
Hi Ravi-san.
Thanks for answer.
And I apologizing my comment too too late.
I understand as first.
the setPropertiy function had bug and it fixed anytime soon.
And can you let me know to the answer for setProperties function(my second question) problem?
