Edge device data replicator for Dev & Test
Do1
9-Granite
9-Granite
When you are do dev work and when testing, you obviously need to do this in the context of data from devices in the field streaming in...
It is not practical to have a set of "test or dev" devices as this would provide neither a realistic breadth of data nor the volume of data against which to dev or test.
I have been wondering how people work with this problem.
This got me to thinking, could one use something like the connection server and then split your updates to two ThingWorx instances?
Any other ideas on how to handle this?
slangley
23-Emerald II
(To:Do1)
Hi @Do1.
For testing ingestion, many customers use simulators for generating the needed volume.  It would be expected that load testing would occur in Test while QA would be used for validating functionality.  In regard to splitting messages from one connection server to 2 different ThingWorx instances, this is not a supported scenario.
Please let us know if you have further questions.
Regards.
--Sharon
slangley
23-Emerald II
(To:Do1)
Hi @Do1.
Regards.
--Sharon
slangley
23-Emerald II
(To:Do1)
Hi @Do1.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
