Hello Everyone,
I created one column of Boolean type and made it as a edited column.
Some times back when user selecting that column from any row it is calling another service and it was working fine.
But today I am facing an issue that it does not working now means when I am selecting that column from any row it does not populated data into edited table and does not coming with infotable.
Can any of the you faced the same issue so you can help me I need it on urgent basis.
Thanks & Regards,
Yash Malik
Hi, can you describe what kind of widget you are using?
