Good morning!
I have integrated an advanced grid into my mashup and filled it with data from various things (which are all derivates from one template).
In the composer, I can already see data as on the image below:
But if I click "view mashup", the data disappears and I cannot even see the columnnames:
Any suggestions on how to solve this problem?
Thank you in advance for any help!!
Best regards,
theresa
Hi Theresa, which ThingWorx version is this? Have you checked the browser's developer console to check for any possible issues? Are you experiencing this in all the browsers? Even in Private/Incognito mode?
Oh yeah, I forgot the application log. Found the problem! Thank you
