Hi All,
need your Help I Run Scheduler for 3 services and i got an error Timeout
(error executing service. Message ::Execution of Script terminated after : 127 seconds. Timeout configured for 120 seconds.)
Regards;
In platform-settings.json you can set the script timeout, since you have a long running service, I recommend increasing that number.
I do recommend you are careful not to have services run too long, so that you don't run into situations where the service hasn't finished yet and you invoke it again.
could you please clarify from where I can change
Hi @Islam_Amer.
Is your question in reference to the timeout setting? If so, here's an example:
"PlatformSettingsConfig": {
"BasicSettings": {
"Storage": "C:\\ThingworxStorage",
"ScriptTimeout": 500
Regards.
--Sharon
Hi @Islam_Amer.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others in the community with the same question.
Regards.
--Sharon
