I have created a service which is running at back end while executing. But, in mashup while clicking the button it was telling like Error from the server: "". I don't understand what is happening. I have tried after restarting also showing the same error.
Thanks.
Maybe you can wrap your service code in a try-catch-block with line number paramter of the error. So you can see where the error was thrown. Maybe this helps to see what is going on.
try {
// service code
catch(err) {
logger.error("Error at " + me.name + ".SERVICENAME [" + err.lineNumber + "]: " + err.message);
try {
// service code
catch(err) {
Hi @Sathishkumar_C.
If you are satisfied with the response previously provided, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
