Error installation Thingworx Foundation 9.1
ML_8931370
I'm trying to install Foundation 9.1 trial, with no success. I have checked the Java version,it's OK. The installer goes on untill step 3, without problem. I can even see the installer creates the folders for the program, but then I receive a message error, telling that the installation failed, and the application will exit. And all the new folders disappear.
PaiChung
22-Sapphire I
(To:ML_8931370)
The only other thing that I can think off is that perhaps it has to do with your language setting and if you could temporarily set it to English (US) and see if that works or not.
18 REPLIES 18
PaiChung
22-Sapphire I
(To:ML_8931370)
TBH I've never used the installer, but I would check your system path make sure it points to the right version of java (Environment Variables/Path)
The other would be perhaps permissions, run as Administrator?
ML_8931370
(To:PaiChung)
I confirm that Java path is OK, and I run installation as administrator.
tdixit
(To:ML_8931370)
Hi @ML_8931370
Could you please send me the installation log file, you can capture that before exiting the installer .
File must be present at the directory where your ThingWorx is getting installed.
Also, please share the value which you are setting in your "JAVA_HOME" and "path" system variable
Toolika Dixit
ML_8931370
(To:tdixit)
I have been trying again in a VM with W10 64, a new installation.
And, unfortunately, I get the same result. I can not send any log files, because the Thingworx folder dissappears when I get the installation error.
I have added the lines for the Path and Java_home values:
Path:
C:\Program Files\Java\jre1.8.0_281\bin
Java_home:
C:\Program Files (x86)\Java\jre1.8.0_281
Thanks for you help!
PaiChung
22-Sapphire I
(To:ML_8931370)
Try getting the log file, before you click 'Aceptar' after the error.
ML_8931370
(To:PaiChung)
I have already tried, but all the files are gone beofre that click...
PaiChung
22-Sapphire I
(To:ML_8931370)
Maybe then try before it even comes to that point? Even if you can't 'copy' the file you might be able to read the content.
ML_8931370
(To:PaiChung)
Not easy to read all the file..., but luckily I was able to copy the log before it dissapeared.
Thanks again!
tdixit
(To:ML_8931370)
Hi @ML_8931370
As suspected by @PaiChung  this is Java related issue. I can see below error in logs
C:\PROGRA~2\THINGW~1\tomcat\current\bin>call service.bat install ThingWorx-Foundation
The JAVA_HOME environment variable is not defined correctly
This environment variable is needed to run this program
NB: JAVA_HOME should point to a JDK not a JRE
You need to set JAVA_HOME properly , the JAVA_HOME should point to a JDK not a JRE and "path" should also point to %JAVA_HOME%/bin
Toolika Dixit
ML_8931370
(To:tdixit)
Sorry, but still didn't arrive to the end on the installation. I dowloaded the JDK and wrote the environment variables. I attach the log for this new trial.
Thanks again!
PaiChung
22-Sapphire I
(To:ML_8931370)
I don't see any errors in the log. But I did notice:
Using JAVA_HOME: "C:\Program Files\Java\jdk-16"
That's the wrong Java_Home I believe
ML_8931370
(To:PaiChung)
I don't know, I haven't found any information about that, but Tdixit told in a former answer that Java_home should be a "jdk", not  a JRE
Regards
Miguel Lage
ML_8931370
(To:ML_8931370)
In case this could help, the last error screen that I get now is the one attached. The point is that, even before pressing "Aceptar", the log file has been erased by the installer.
PaiChung
22-Sapphire I
(To:ML_8931370)
ML_8931370
(To:PaiChung)
Yes, there was some issue about language settings. Finally, I changed the Windows language to US English, and the installation has run correctly until the end. The application is working!
Thanks for your kind help!
Miguel Lage
PaiChung
22-Sapphire I
(To:ML_8931370)
Can you please report this issue to support.ptc.com?
thanks!
ML_8931370
(To:PaiChung)
I am using the trial version, so, I believe that I can not open a Support case.
Miguel Lage
PaiChung
22-Sapphire I
(To:ML_8931370)
That JDK though  should also be in that 8. something folder vs. this strange 1-6 it is pointing to.
