Error installing Thingworx H2 Trial 8.4 version
Regular Member
I have an error when I'm trying to install Thingworx H2 trial 8.4 version. The error is the next message:
"Problem running post-install step. Installation may not complete correctly
Error running .\check-http-response--username: "Administrator" --password:****--hostname "localhost" -- hostport "8084" --useSSL=0:1 "
I execute in administrator mode and with other ports but I don't know how to solve this problem. Any idea? Iread this post:
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-8-4-Trial-Warning-Problem-running-post-i...
But that solution doesn´t work for me, I have the correct system requeriments. Could you help me with this?
Thank you in advance
BR
Luis
Re: Error installing Thingworx H2 Trial 8.4 version
Hi @ljam.
Apologies for the issues you are experiencing.
If you have validated that your system conforms with the requirements, you will need to follow the manual install process to circumvent the issues:
ThingWorx 8.4 System Requirements
Installing ThingWorx 8
We will have new installers available once ThingWorx 8.5 is released.
--Sharon
Thank you for your answer Sharon, but with Trial 8.4 version I think that you can't do the manual install because the file is .exe. Correct me if It isn't that way.
Thank you
BR
--Luis
Hi @ljam.
Apologies--you are correct.  We also have installers for commercial versions and I confused that with the trial versions.
We will have new trial versions available once ThingWorx 8.5 is released which may circumvent the problems.  In the meantime, can you provide your hardware configuration?  Are you installing the Linux or Windows version?
--Sharon
Hi @slangley
Don't worry. I installed Thingworx on Windows 7 64-bit and my hardware is the next:
i7-6820HQ 2.7GHz
16 GB RAM
1 TB disk space
Do you know when Thingworx 8.5 trial is released?
Thank you
BR
--Luis
Hi @ljam.
It sounds like you have an acceptable configuration but wanted to be sure you saw the Windows trial installation guide located here.  Step 2 of this guide reviews the java version needed.  Please validate that you have installed Oracle version 8 64-bit.  Open JDK is not supported.
If that is not the cause of the issue, please let us know and we will keep digging.
To answer your question regarding the availability of the 8.5 trial version.....I was told it would take about 6 weeks from the release of ThingWorx 8.5 before the trials could be made available.  Assuming there are no delays in the release, we are looking at some time in November for the availability of the 8.5 trial.
--Sharon
