Start a topic
Search
LogIn
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Please log in to access translation
Turn on suggestions
Close X
  • Community
  • ThingWorx
  • ThingWorx Developers
  • Re: Error opening non-TLS socket[localhost:8001]
Options
  • Subscribe to RSS Feed
  • Mark Topic as New
  • Mark Topic as Read
  • Float this Topic for Current User
  • Bookmark
  • Subscribe
  • Mute
  • Printer Friendly Page
gquiroga
gquiroga 12-Amethyst
‎May 31, 2018 03:30 PM
  • Mark as New
  • Bookmark
  • Subscribe
  • Mute
  • Permalink
  • Print
  • Notify Moderator
When running wsems I get the following errors:
UnencryptedClientStream::doopen:Error opening socket. Error: 111
HttpClient::initialize: Exception while opening connection request to localhost. Error: Error opening non-TLS socket [localhost:8001]
Labels:
  • Labels:
  • Connectivity
  • Troubleshooting
  • Tags:
  • ems
  • Thingworx Edge Micro Server
  • Thingworx EMS
0 Kudos
Reply
Notify Moderator
  • All forum topics
  • Previous Topic
  • Next Topic
smanley
smanley 14-Alexandrite
(To:gquiroga)
‎May 31, 2018 04:29 PM
  • Mark as New
  • Bookmark
  • Subscribe
  • Mute
  • Permalink
  • Print
  • Notify Moderator
Are you using a self signed certificate to connect the WSEMS? We have an article that may help you resolve the issue.
EMS and LSR are unable make a connection to SSL enabled ThingWorx server using EMS 5.4.0
  • Below are the sample config.json and config.lua that will work for a server with self signed certificate
  • Please find detailed explanation with examples from the Edge Help Center
WS EMS - Config.json
"http_server": {
"host": "localhost",
"port": 8000,
"ssl": true,
"authenticate": false,
"use_default_certificate" : true
"certificates": {
"validate": false,
"allow_self_signed": true
LSR - config.lua
-- EMS Connection Configuration
scripts.rap_host = "localhost"
scripts.rap_port = 8000
-- EMS Connection TLS Configuration
scripts.rap_ssl = true
scripts.rap_deny_selfsigned = false
scripts.rap_validate = false
-- EMS Connection Authentication
-- Configuration
scripts.rap_server_authenticate = false
-- HTTP Server Configuration
scripts.script_resource_host = "localhost"
scripts.script_resource_port = 8001
-- HTTP Server TLS Configuration
scripts.script_resource_ssl = true
scripts.script_resource_use_default_certificate = true
-- HTTP Server Authentication
-- Configuration
scripts.script_resource_authenticate = false
PTC
0 Kudos
Reply
Notify Moderator
gquiroga
(To:smanley)
‎May 31, 2018 04:44 PM
  • Mark as New
  • Bookmark
  • Subscribe
  • Mute
  • Permalink
  • Print
  • Notify Moderator
Hi smanley,
That is the configuration I've got on both the config.json and the config.lua files.
When I try to run the LSR it get's stucked on "Initializing TLS Client" even if SSL is deactivated.
0 Kudos
Reply
Notify Moderator
ShravanS
ShravanS 6-Contributor
6-Contributor
(To:gquiroga)
‎Sep 10, 2018 05:43 PM
  • Mark as New
  • Bookmark
  • Subscribe
  • Mute
  • Permalink
  • Print
  • Notify Moderator
Hi gquiroga,
Did you get it working? I am facing the same issue here
0 Kudos
Reply
Notify Moderator
Contact Community Management
About
PTC.com Products & Solutions Contact
Resources
My PTC - Support PTC University Help Center - Product Guides Product Documentation Success Paths - Planning &
Implementation Guides
Other PTC Communities
Onshape PTC user
Terms of Service Privacy Policy
facebook twitter linkedin youtube
Powered by Khoros
