I have a testUser inside a userGroup inside myOrganization
I configured SMTP Mail Server for Outbound Messaging (using outlook)
To test Service I use SendMessage method. It works fine
My problem comes after using reset password inside myOrganization login form.
I get the following messages:
Warn | User [testUser] is a member of [myOrganization] and has confirmed their personal information - sending reset email | SuperUser | S.c.t.s.a.ThingworxFormAuthenticator | https-jsse-nio-8443-exec-56 |
then
Error | Error sending email to the following invalid addresses: null | S.c.t.t.m.MailThing | https-jsse-nio-8443-exec-56 |
and finally
Error retrying to send an email to valid recipients after invalid ones caused a failure, or failure to send an error email about this event: 501 5.1.7 Invalid address_ | S.c.t.t.m.MailThing | https-jsse-nio-8443-exec-56 |
I'm not understanding the error or how to solve it, the email address is correct as I have confirmed it, it seems the email address is getting lost in some part of the function, Could you please give more detail on those messages and a workaround?
Hello, I've been trying to make it work but I am not able to do so, I double checked the configuration for
Mail server (valid email, send message work fine, no reply, reply and error mails are correct too), organization, user information (fisrtName, lastName, emailAddress) and that user is part of composer group. However I am Still getting the message:
Normally we create a thing that extends MailServer, so do you check these configurations(Mail Account User,Default From Field,No-Reply Address,Reply Address,Error Address) of this thing instead of the MailServer template?
There is this Mail Server Thing template
I extended it using myEmailServer:
Then in organization
I added myEmailServer
Still not able to solve the issue
Yes I double checked them, I also tested the send email function to test functionality and is working
There must be a little detail I am missing
