I am attemping to unstall thingworx flow on thingworx foundation 8.5. I have not been ale to get Thingworx Flow running. After running the installer, this error appears in the installer log:
Executing sc
Error running sc query ThingWorx-Flow: Program ended with an error exit code
[10:48:22] - Previous installation of ThingWorx-Flow found: flow_service_exists
There was no previous installation of Thingworx flow attempted on the machine I was using.
for more context, these errors appear in the flow-engine-logs:
{"module":"engine-exchange-helper","timestamp":"2020-06-03T18:31:38.469Z","level":"error","message":"Unable to process request for csrf connect ECONNREFUSED 127.0.0.1:7822"}
{"module":"engine-exchange-helper","timestamp":"2020-06-03T18:31:38.471Z","level":"error","message":"Exchange Request Failed {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":7822}"}
{"module":"exchange-handler","timestamp":"2020-06-03T18:31:38.471Z","level":"error","message":"isExchangeRunning.catch error: Error: connect ECONNREFUSED 127.0.0.1:7822 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1191:14)"}
Hi @AndrewMckinney.
The error message you provided indicates you have made multiple attempts to install the product. In order to re-install, all remnants from the previous installation have to be removed manually. It would be good to know why the installation failed initially, but I'm assuming you don't have those logs.
It would be best to open a case for this so that one of our engineers can walk you through the process of removing the artifacts from the previous installation attempts. If you can provide your corporate email address and company name for your PTC support account (under private email), I will be happy to open the case on your behalf.
Regards.
--Sharon
Hi @AndrewMckinney.
Did you open a case for your issue or were you able to resolve it on your own?
Please let us know how we can help.
Regards.
--Sharon
