I've downloaded the Relational Database Connectors Extension from the marketplace but while importing it in Thingworx Composer I get 'Not Acceptable' validation error. The extension downloads a zip file which has separate zip files for each type of DBs.Help.
One potential issue is that if you have for example the Postgres version of Thingworx, that extension is already installed.
I recommend taking the extensions out of the zip and then importing them individually
