Every time I want to create signals or profiles I got errors
bakrim
7-Bedrock
I got this error every time I want to create signals or profiles. :
[context: com.thingworx.webservices.context.HttpExecutionContext@6dbd4d1d][message: Execution error in service script [CreateSignalAMS] :: JavaException: com.thingworx.common.exceptions.GenericHTTPException: Got error code [502] from service [SignalsMicroserver] method [CreateJob] (CreateSignalAMS#69)]
nsampat
(To:bakrim)
Sorry to hear that restarting the applciation did not resolve the issue.
With the ThingWorx Trial Edition (TTE) there is no solution for microservice corruption if a restart does not resolve the issue.
I would recommend un-installing TTE, removing the install directory, then re-install TTE.
Neel
nsampat
(To:bakrim)
Thank you for your Post.
I have some clarifying questions for you:
  • What version of ThingWorx Analytics are you using?
  • What Operating System are you using?
  • What kind of deployment is this?
    • e.g. Analytics Trial Edition, ThingWorx Trial Edition, Docker Based Installation, Native Based Installation
  • Have you attempted to restart the ThingWorx Analytics Application?
I look forward to your response,
Neel
bakrim
7-Bedrock
(To:nsampat)
Sorry I marked the post solved by mistake
    Component Name: ThingWorx Analytics Server
    Version: 8.2.0-r2
    Windows 10
    Analytics Trial Edition /  DOCKER
    YES, BUT I STILL HAVE THE  SAME ERROR
nsampat
(To:bakrim)
Neel
