Execute a .exe file in ThingWorx 9.3.8
Akj7579
Hi
Is it possible to execute a .exe file in the SystemRepository of ThingWorx 9.3.8. If yes, how to do it?
Thanks in Advance...
Hi @Akj7579   Look at the below article.
https://www.ptc.com/en/support/article/CS294967
odukiya
(To:Akj7579)
Hello @Akj7579
Executing an .exe file is not a part of thingworx functionality due to security reason however you can either create custom extension to achieve your use case. Please refer the article shared above.
I just want to understand what is the purpose of executing .exe in system repository folder whats the exact use case?
