Expired License
dbseger
Expired License
I have an install of Thingworx that I let the license expire on.  In my attempt to re-license I encountered some problems and nothing seemed to work.  I'm the point were I gone so far as to delete everything from the ThingworxPlatform directory and left only the platform-settings.json file.  Upon restarting, the keystore-password file is created but nothing else.  No licenseRequestFile.txt or ignore_license_capability_responce.bin files are created.  I've tried using the old licenseRequestFile.txt file and I downloaded a new license_capability_responce.bin file but that didn't work either.
Any suggestions on what to try next?
slangley
(To:slangley)
Hi @dbseger.
As you know, the solution was to clear the contents of \ThingworxStorage and \ThingworxPlatform including the keystore-related files.  The downside is that the application keys that were previously in use, were rendered unusable so new ones had to be created for any connections.
If you agree with this summary of the solution, please mark this post as the Accepted Solution for the benefit of others with the same issue.
--Sharon
6 REPLIES 6
suverma
(To:dbseger)
Hi @dbseger
Here are some links for license installation that can help you proceed further with installation:
Thingworx Licensing
Acquire License in Thingworx
You can also trying clearing your license cache if that helps, following these links:
How to clear corrupted license trusted storage in ThingWorx Platform
Note: Please ensure you are giving correct deviceID while generating new license.
dbseger
(To:suverma)
@suverma
Thanks for the reply.  I've tried the procedures covered in the first two links you provided with no success.  The third one is not publicly accessible.
slangley
(To:dbseger)
Hi @dbseger.
We will need to create a case for addressing this issue.  I will be happy to open one on your behalf with your approval.
--Sharon
Please do.  Thanks.
slangley
(To:dbseger)
Hi @dbseger.
The case has been opened and I will be reaching out to schedule a screen share.  Once we determine the cause of the issue, I will post an update here.
--Sharon
slangley
(To:slangley)
Hi @dbseger.
--Sharon
