Exporting/Importing from ThingWorx 7 to ThingWorx 6
pnali
I have recently installed thingworx 7, so i am trying to export entity and data from version 7. So, is there a way to export entities.xml and data.json file from thingworx version 7 and then import it to thingworx 6. Can anyone help me regarding this issue.
7 REPLIES 7
Aanjan
(To:pnali)
Preethi, is there a reason why you are downgrading? Please do note that certain (new) entities and basetypes exist in 7.x, and it will not import in 6.x.
pnali
(To:Aanjan)
I have installed thingworx 7 in my system but in aws cloud we have thingworx 6 and I want to run my mashup in cloud. I tried installing thingworx 7 in aws but in prerequisite for installing version 7, it is specified that 100GB memory is required and my aws cloud available space is only 40GB. Can you suggest any other way. Thanks for replying.
Aanjan
(To:pnali)
If you're talking about disk space, the default bare bones ThingWorx install shouldn't take more than 300-400mb (with/ including Postgres install). The actual size is entirely dependent on your application and how/ where data gets stored. You should be fine with 40 gigs for starters; I'm assuming you can increase the space if required.
pnali
(To:Aanjan)
I tried installing version 7.x but I am getting the following error.error.png
Aanjan
(To:pnali)
Is that the Postgres version? Do you have Postgres 9.4 installed? Please do post your Catalina log from Tomcat/logs folder and Application log from the ThingworxStorage folder.
pnali
(To:Aanjan)
This is log file of application from thingworxstorage
2016-09-08 10:18:53.693+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
AlertProcessingSubsystem#,         maximumQueueSize= 50000.0, queueSize= 0.0, totalAlertsQueued= 0.0,
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 16578.0, completedTaskCount= 16578.0,
FederationSubsystem#,              clientCount= 0.0, publishedCount= 0.0, updateInterval= 100.0,
FileTransferSubsystem#,            corePoolSize= 10.0, maxPoolSize= 10.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
MessageStoreSubsystem#,            corePoolSize= 10.0, maxPoolSize= 100.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.3932208E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
StreamProcessingSubsystem#,        maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 250000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
TunnelSubsystem#,                  activeTunnelCount= 0.0, totalTunnelCount= 0.0,
UserManagementSubsystem#,          userCount= 21.0,
ValueStreamProcessingSubsystem#,   maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
WSCommunicationsSubsystem#,        activeWebsockets= 0.0,
WSExecutionProcessingSubsystem#,   corePoolSize= 1000.0, maxPoolSize= 10000.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
ThingworxServer#,                  systemRuntime= 46 hours,  memoryInUse = 0.239 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 10:18:53.752+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.39490544E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 46 hours,  memoryInUse = 0.24 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.39607608E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.753+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.39720008E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.39837072E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.754+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.39949472E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40066536E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.755+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40178936E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.756+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40296E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.4041108E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.757+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40523464E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 46 hours,  memoryInUse = 0.241 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40640536E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.758+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40752944E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40870016E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.759+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40982424E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41099496E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.760+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41211904E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41328976E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.761+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41441384E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41558456E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 46 hours,  memoryInUse = 0.242 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41670864E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41785224E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.762+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.41902392E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.42015504E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.763+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.4212992E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.42245032E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.764+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.42359448E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.765+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.42474568E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 46 hours,  memoryInUse = 0.243 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.42589664E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.766+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.4270408E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:18:53.767+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.42819192E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
2016-09-08 10:47:12.723+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 16748.0, completedTaskCount= 16748.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.29847504E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 46 hours,  memoryInUse = 0.23 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 11:17:12.713+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 16928.0, completedTaskCount= 16928.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.31443568E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 47 hours,  memoryInUse = 0.232 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 11:47:12.709+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 17108.0, completedTaskCount= 17108.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.3570884E8, totalMemoryAllocated= 2.6738688E8, thingCount= 162.0,
ThingworxServer#,                  systemRuntime= 47 hours,  memoryInUse = 0.236 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 11:58:32.260+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Error occurred while validating HTTP parameter: reason
2016-09-08 12:01:44.961+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@cdd6191][message: Invalid Request ]
2016-09-08 12:01:51.988+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@a05851a][message: Invalid Request ]
2016-09-08 12:03:23.191+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@5adf7c10][message: Invalid Request ]
2016-09-08 12:03:30.224+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@4598aef6][message: Invalid Request ]
2016-09-08 12:03:37.251+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@38391544][message: Invalid Request ]
2016-09-08 12:03:44.279+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@3d1f870c][message: Invalid Request ]
2016-09-08 12:03:51.301+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@6821986][message: Invalid Request ]
2016-09-08 12:03:58.322+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@54cec601][message: Invalid Request ]
2016-09-08 12:04:05.349+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1fc070b0][message: Invalid Request ]
2016-09-08 12:04:12.374+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@6e7a4cab][message: Invalid Request ]
2016-09-08 12:04:19.393+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@3fc10ada][message: Invalid Request ]
2016-09-08 12:04:26.425+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@52090a92][message: Invalid Request ]
2016-09-08 12:04:33.456+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4e2004e2][message: Invalid Request ]
2016-09-08 12:04:40.478+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@44d350e7][message: Invalid Request ]
2016-09-08 12:04:47.505+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@11ab3e64][message: Invalid Request ]
2016-09-08 12:04:54.533+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@799a642d][message: Invalid Request ]
2016-09-08 12:08:10.343+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:10.346+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:10.626+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:10.627+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:10.824+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-4] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:15.552+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:15.554+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:15.593+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-4] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:15.594+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-4] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:15.623+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:15.661+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-5] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:16.176+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-2] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:16.177+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-2] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:08:21.963+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@6f7f73e7][message: Invalid Request ]
2016-09-08 12:08:29.125+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@bbdb69e][message: Invalid Request ]
2016-09-08 12:08:36.146+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@74cf8cad][message: Invalid Request ]
2016-09-08 12:08:43.166+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@10ed7a2][message: Invalid Request ]
2016-09-08 12:08:50.181+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@68112617][message: Invalid Request ]
2016-09-08 12:09:08.721+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@2d85c7b9][message: Object With This Name Does Not Exist]
2016-09-08 12:10:43.713+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@7defe0b2][message: Object With This Name Does Not Exist]
2016-09-08 12:10:50.733+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@48094914][message: Object With This Name Does Not Exist]
2016-09-08 12:11:38.693+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] Error occurred while validating HTTP parameter: reason
2016-09-08 12:12:36.500+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] Error occurred while validating HTTP parameter: reason
2016-09-08 12:14:36.037+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] Error occurred while validating HTTP parameter: reason
2016-09-08 12:15:32.313+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Start migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:15:32.313+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Finished migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:15:32.313+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Start migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:15:32.313+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Finished migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:15:32.313+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Starting entity import
2016-09-08 12:15:32.356+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Thing [Test_Thing] has logged properties but does not have a valid value stream assigned
2016-09-08 12:15:32.358+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Entity import successful
2016-09-08 12:15:32.358+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-5] Start post migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:15:32.358+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-5] Finished post migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:15:32.359+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-5] Start post migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:15:32.359+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-5] Finished post migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:17:02.897+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@58fdccd][message: Unable to Invoke Service GetRemoteMetadata on BLEThing : BLEThing is not connected]
2016-09-08 12:17:02.981+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:02.982+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:05.246+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:05.247+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:12.713+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 17288.0, completedTaskCount= 17288.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.47058656E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 48 hours,  memoryInUse = 0.247 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 2, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 12:17:17.285+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:17.328+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-1] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:17.329+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-1] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:17.464+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-6] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:17.465+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-6] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:17:47.998+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] Error occurred while validating HTTP parameter: reason
2016-09-08 12:17:50.919+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@75b65b8b][message: Unable to Invoke Service GetRemoteMetadata on BLEThing : BLEThing is not connected]
2016-09-08 12:32:33.888+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:32:38.370+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:32:38.371+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:33:13.013+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Start migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:33:13.013+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Finished migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:33:13.013+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Start migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:33:13.013+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Finished migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:33:13.013+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Starting entity import
2016-09-08 12:33:13.021+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Entity import successful
2016-09-08 12:33:13.021+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Start post migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:33:13.021+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Finished post migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:33:13.021+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Start post migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:33:13.021+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Finished post migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:35:42.778+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Error occurred while validating HTTP parameter: reason
2016-09-08 12:36:57.913+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Error occurred while validating HTTP parameter: reason
2016-09-08 12:37:24.629+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Error occurred while validating HTTP parameter: reason
2016-09-08 12:43:55.132+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:44:02.359+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-8] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:44:02.360+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-8] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:44:02.460+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-3] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:44:02.664+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-1] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:44:02.665+0530 [L: ERROR] [O: E.c.t.s.f.ValidatingHttpRequest] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-1] Error occurred while validating HTTP header: If-None-Match
2016-09-08 12:47:12.701+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 17468.0, completedTaskCount= 17468.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.4236872E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 48 hours,  memoryInUse = 0.242 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 2, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 12:56:59.939+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Start migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:56:59.940+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Finished migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:56:59.940+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Start migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:56:59.940+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Finished migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:56:59.940+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Starting entity import
2016-09-08 12:57:00.431+0530 [L: ERROR] [O: c.t.c.ImportProcessor] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Unable to process import: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]
2016-09-08 12:57:00.433+0530 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Entity import failed
2016-09-08 12:57:00.433+0530 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [message: Import Failed: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]]
2016-09-08 12:57:00.434+0530 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] Internal error: java.lang.Exception: Import Failed: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]
2016-09-08 12:57:00.443+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-6] Start post migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:57:00.443+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-6] Finished post migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:57:00.443+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-6] Start post migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:57:00.443+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-6] Finished post migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:57:13.671+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Start migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:57:13.671+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Finished migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:57:13.671+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Start migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:57:13.671+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Finished migrating from version [6.6.0] to version [6.6.0].
2016-09-08 12:57:13.671+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Starting entity import
2016-09-08 12:57:14.125+0530 [L: ERROR] [O: c.t.c.ImportProcessor] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Unable to process import: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]
2016-09-08 12:57:14.126+0530 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Entity import failed
2016-09-08 12:57:14.127+0530 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [message: Import Failed: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]]
2016-09-08 12:57:14.127+0530 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] Internal error: java.lang.Exception: Import Failed: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]
2016-09-08 12:57:14.131+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Start post migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 12:57:14.131+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Finished post migrating from version [6.5.0] to version [6.5.0].
2016-09-08 12:57:14.131+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Start post migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 12:57:14.131+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-9] Finished post migrating from version [6.6.0] to version [6.6.0].
2016-09-08 13:17:12.696+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 17648.0, completedTaskCount= 17648.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.49196864E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 49 hours,  memoryInUse = 0.249 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 2, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 13:47:12.694+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 17828.0, completedTaskCount= 17828.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.48093424E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 49 hours,  memoryInUse = 0.248 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 13:50:33.236+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Start migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 13:50:33.237+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Finished migrating from version [6.5.0] to version [6.5.0].
2016-09-08 13:50:33.237+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Start migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 13:50:33.237+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Finished migrating from version [6.6.0] to version [6.6.0].
2016-09-08 13:50:33.237+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Starting entity import
2016-09-08 13:50:33.549+0530 [L: ERROR] [O: c.t.c.ImportProcessor] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Unable to process import: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]
2016-09-08 13:50:33.551+0530 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Entity import failed
2016-09-08 13:50:33.552+0530 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [message: Import Failed: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]]
2016-09-08 13:50:33.564+0530 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] Internal error: java.lang.Exception: Import Failed: Validation Failure: Thing InsuranceThingLab1 Had An Invalid DataShape [DailyPremiumDataShapeLab] assigned to the result type in service [DailyPremiumLab]
2016-09-08 13:50:33.569+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Start post migrating from version [6.5.0] to version [6.5.0] ...
2016-09-08 13:50:33.570+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Finished post migrating from version [6.5.0] to version [6.5.0].
2016-09-08 13:50:33.570+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Start post migrating from version [6.6.0] to version [6.6.0] ...
2016-09-08 13:50:33.570+0530 [L: INFO] [O: c.t.migration] [I: ] [U: ] [S: ] [T: http-nio-8080-exec-10] Finished post migrating from version [6.6.0] to version [6.6.0].
2016-09-08 14:17:12.699+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 18008.0, completedTaskCount= 18008.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.4151632E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 50 hours,  memoryInUse = 0.242 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 2, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 14:47:12.689+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 18188.0, completedTaskCount= 18188.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.4748016E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 50 hours,  memoryInUse = 0.248 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 2, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 15:17:12.681+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 18368.0, completedTaskCount= 18368.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.330128E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 51 hours,  memoryInUse = 0.233 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 15:47:12.669+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 18548.0, completedTaskCount= 18548.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.37227496E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 51 hours,  memoryInUse = 0.237 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 16:17:12.644+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 18728.0, completedTaskCount= 18728.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.40120112E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 52 hours,  memoryInUse = 0.24 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 16:47:12.661+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 18908.0, completedTaskCount= 18908.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.49982752E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 52 hours,  memoryInUse = 0.25 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 17:17:12.638+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 19088.0, completedTaskCount= 19088.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.45691912E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 53 hours,  memoryInUse = 0.246 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 17:47:12.655+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 19268.0, completedTaskCount= 19268.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.35412848E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 53 hours,  memoryInUse = 0.235 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 18:17:12.634+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 19448.0, completedTaskCount= 19448.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.45085328E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 54 hours,  memoryInUse = 0.245 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2016-09-08 18:47:12.625+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-6-thread-1]  Thingworx System Metrics
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 19628.0, completedTaskCount= 19628.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.34557136E8, totalMemoryAllocated= 2.6738688E8, thingCount= 164.0,
ThingworxServer#,                  systemRuntime= 54 hours,  memoryInUse = 0.235 GB,  totalMemoryAllocated= 0.267 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
Aanjan
(To:pnali)
Can you possibly post both the Application log and the Catalina log in a text file and attach that?
