Exporting the entities from thingworx 6.5 to thingworx 7.2
ngourav
Hi All,
Can i get any document for exporting the entities from thingworx 6.5 and importing it to thingworx 7.2.
As I am getting an error after importing when I am running my services I am getting the following error :
"Error While Executing SetGenset Service :  JavaException: java.lang.RuntimeException: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]"
If someone has any idea what this error means and also If someone can share the doc for doing the above step.
Naveen
ankigupta
(To:ngourav)
Hi Naveen Gourav​,
Did you select the Use Default persistence provider option while importing the data.
And please refer to the following article which mentions about the same error: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS239982&lang=en_US
Hi Ankita ,
I already have tried .
