Extension Google Map
AC_9552412
Hello, I have imported a modified google map widget extension but it does not appear in widgets, I have another modified google map widget extension but with another name, can it be a reason why the extension does not appear?
9 REPLIES 9
Hello @AC_9552412 ,
Pls check the following article for the same:
https://www.ptc.com/en/support/article/cs188314
Kindly let me know if you have any further queries.
Bhawna
hello, it is not the same problem, the google map extension that I have imported does not appear in the widget box
slangley
(To:AC_9552412)
Hi @AC_9552412
This is usually a caching problem.  Try clearing your browser and restarting ThingWorx.
--Sharon
Hello @AC_9552412 ,
Sometimes this widget does not respond in Google Chrome and Firefox browser. Pls try in Internet Explorer.
Bhawna
Hello, @bchaudhary
I tried with other browser and the same thing happens
slangley
(To:AC_9552412)
Hi @AC_9552412.
I haven't seen this problem for a while.  What version of ThingWorx are you running?  Have you tried restarting Tomcat?
Note that Internet Explorer is no longer a supported browser.
--Sharon
hi @slangley
The version is 8.5. I have restarted tomcat but it still does not appear.
slangley
(To:AC_9552412)
Hi @AC_9552412.
Did you try clearing your browser cache, then restarting your browser?  Which version of the Google Maps extension did you import?
--Sharon
Porcelain_
6-Contributor
(To:AC_9552412)
Try Edge browser.
