Hi all,
I am trying to import a customized XY chart from Eclipse into ThingWorx. I can import the extension successfully but the extension doesn't work. When I checked the application log, I see a message saying "export file missing version information. No migration will be performed." which I think may be the cause of this issue. Attached is the zip file for some reference. Any help will be greatly appreciated!
Hi @kahmeng96
The message in the application log can be ignored. For more information, you can refer this article CS287147
Vibhuti
Hi @kahmeng96
Vibhuti
Thanks for the reply. I figured that the import was successful as it was not an error message, therefore it should be an issue on the code side.
