External db
Sruthi
External db
can I connect postgresql as a external db connection to Thingworx 90 days trial version?
slangley
(To:Sruthi)
Hi @Sruthi.
The extension needed has been moved to the downloads section of the support site, which requires a support contract in order to access.  I recommend contacting our Sales team and explain the situation.  As a potential customer, they will be able to provide you with the artifacts needed for completing your review of the product.
Regards.
--Sharon
PaiChung
22-Sapphire I
(To:Sruthi)
Obviously possible in the full version, if the trial version is H2 connected then you would need to at least be able to import a jdbc connector extension. If it is already postgres you should be able to create another database  Thing connector.
Could just try?
Sruthi
(To:PaiChung)
I am using trial version with H2. can I get the  jdbc connector extension?? I am not finding any extension related to jdbc in market place
PaiChung
22-Sapphire I
(To:Sruthi)
If they aren't on the marketplace then I'm not too sure where to get them, I'm very sorry.
slangley
(To:Sruthi)
Hi @Sruthi.
Regards.
--Sharon
