Hi there, I'm trying to extract a row from the infotable as per the code below.
var table = me.myInfoTable;
var someRow = table.rows[0];
var result = someRow;
After executing the script I'm getting the following error (composer). Why is that? I'm pretty sure I could do it before.
The infotable is not empty. The data can be accessed by addressing field names.
var someName = someRow.someField;
The output is set to an infotable with the appropriate datashape.
You are not adding the row you got to infotable
you should do as like
var params = {
infoTableName : "InfoTable",
dataShapeName : "testds"
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var devices = Things["Remote"].GetDataTableEntryByKey({key:'uhii'});
var row = devices.getRow(0);
result.AddRow(row)
var params = {
result.AddRow(row)
Nilesh Khose, thank you! It worked.
Although I did not explicitly create a separate infotable using the functions provided, perhaps you could explain why I can access those fields as per the code below?
A method of accessing row fields (without creating a separate table and adding rows to it) is used quite broadly.
The question arises - what is a value collection in the context of ThingWorx? Thanks.
Hi mnudel,
Here someName is a value collection. In general it's an object or array of different type of elements.
We can refer to elements by <value_collection>.<field_name>.
It is to add a row to an infotable in ThingWorx or refer to an element/cell of an infotable.
I hope it helps.
