Facing issues in styling the mashups
H_1234
11-Garnet
In one of my application, I have given some manual styles to some containers, like Background color, font style, font size.
But after navigation, the styles are getting reverse back to the default style.
So, can anyone help me to find the solution to this issue?
Or any specific reason why is it happening?
I am also attaching some snaps below for the reference.
Thanks in advance.
Hareef.
bchaudhary
(To:H_1234)
Hello @H_1234 ,
Can you pls share the following:
1. ThingWorx Version
2. Sample entities if possible
3. While you are navigating, are you using the similar design?
Bhawna
Hi @bchaudhary,
1. ThingWorx Version - ThingWorx 9.1.1-b483
2. I can't share the entities as its confidential.
3. Yes, i am using similar design while navigation but still facing the same issue.
Can you tell me what could be the reason behind this?
How can i fix this issue or any work around?
Hareef.
bchaudhary
(To:H_1234)
Hello @H_1234 ,
In that case, I would recommend you to check the Styleproperties.
Are you using the default styleproperties or the custom Styleproperties?
In my opinion, you must use default style properties if you are opting custom.
pls revert back if you have any further queries.
Bhawna
