With a fresh install using the textual installer using all defaults.
if I run
$ catalina.sh stop $ catalina.sh start
I get the error:
*** CRITICAL ERROR ON STARTUP: Improper value found for model provider configuration password, system cannot start without valid password *** Web Application STATE is being set to ERROR! ***
If I destroy the VM and reinstall, foundation runs fine after the install. But any attempt to restart will not start.
The config for h2 (created by the installer) contains
"PersistenceProviderPackageConfigs": { "H2PersistenceProviderPackage": { "ConnectionInformation": { "password": "\u003caddsecurepassword\u003e", "username": "twadmin" } } },
(This is after finishing up the install of the analytics server, so it would really suck to have to start all over again)
Sorry, had a syntax error in the json unrelated to the h2 password. The exception indicated this further up on the log. The message threw me off.
