File uploading to ThingWorx repository
SOLVED
Highlighted
Regular Member
I have a scenario where we need to connect to the local computer and read the same CSV file to ThingWorx repository. I was checking on File Upload widget. But in this case since the file is getting generated in a time periodic manner can not upload it manually.
Could someone suggest how can we automate this process to read the CSV file from local computer to Thingworx repository !!
1 ACCEPTED SOLUTION
Highlighted
Re: File uploading to ThingWorx repository
You should use a a RemoteThingWithFileTransfer remote thing, that implies to install a TW Edge Agent where the files reside and it will be connected always to ThingWorx, that way you can upload/download remote files easily.
Here you have the documentation of TW Edge capabilities: http://support.ptc.com/help/thingworx_hc/thingworx_edge/ you should look at ThingWorx WebSocket-based Edge Microserver (WS EMS), and there you have the following documentation on how to configure File Transfers: http://support.ptc.com/help/thingworx_hc/thingworx_edge/#page/latest%2Fws_ems%2Fc_ems_wsems_configur...
Highlighted
Highlighted
Thank you CarlesColl :)
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
