Find element infotable CSDK
AliBenBelgacem
I have a csdk prorgam, i need to search specific element on infotable.
I am trying to use the function twList_Foreach(twList *list, twForEachHander listHandler, void *userData) to find and update row on the infotable, but i am not succeeding.
Can someone provide me with a sample to use this method please?
my infotable contains 4 strings [field A , field B , field C , field D] ,
i am searching the row where B=='some specific string'
if true update the row.
Thank you very much for your help
Rocko
(To:AliBenBelgacem)
No working example, but the CSDK has some usages of it, just search for twList_Foreach. Some sample files using twList_Foreach are:
BindingIntegrationTests.c (in test/integration)
twInfoTable.c (in src/messaging)
twList_Foreach will iterate all rows, so your handler will be called for each row. Therefore you need to check for your condition B=='some specific string' in the handler (and exit/return) if it doesn't match.
You could also try to use twList_Find instead, a sample you can find in unit_twList_Find.c
Rocko
(To:AliBenBelgacem)
