The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Finding data in json from an infotable.
MR_10404102
6-Contributor
Can somebody help me to write a service in thingworx where infotable data value is checked if it is found in a json data.
Thanks.
  • Iterate the infotable
  • Compare values with JSON from infotable
  • if found, get the required values
var info = [INFOTABLE];
for( var  i = 0; i < info.length; i++){
   //Get the infotable row values
   //Search in JSON
   if(isFound == true){
      //Get the required value
If possible share the sample dataset.
3 REPLIES 3
Can you please explain bit more about your use case?
I have a json data which has multiple json arrays. I have an infotable which has data which can be compared to the json data. If at all i find the value in the json then i have to get certain key value pairs of that object.
   //Search in JSON
