I'm having a problem getting Flow 10 to get configured with Foundation 10. All the services start and I can connect to Foundation via the Flow nginx port but I get the following error when running WorkflowSubsystem.ValidateFlowSetup:
Found 1 issues. [FLOW-API-01] - Failed to connect to Flow: Internal Server Error For more information, refer to the 'Troubleshooting Your Installation' topic in the Help Center.
The ApplicationLog has these errors:
2025-11-21 14:29:06.092+0000 [L: ERROR] [O: c.t.s.s.f.WorkflowSubsystem] [I: ] [U: Administrator] [S: ] [P: ] [T: https-openssl-nio-8443-exec-7] Failed to get Delegated UserOAuths : Internal Server Error
2025-11-21 14:29:06.092+0000 [L: ERROR] [O: c.t.f.f.FlowDelegatedOAuthFilter] [I: ] [U: Administrator] [S: ] [P: ] [T: https-openssl-nio-8443-exec-7] Unable to initialize session attributesI don't have SSO currently enabled although I did have it on in previous attempts so I'm not sure with there is an OAuth error.
Thanks but ErrorLog didn't really contain anything valuable. The Flow exchange error had this:
{"module":"flow-exchange","timestamp":"2025-11-25T01:10:37.462Z","level":"error","message":"unauthorized access”}And the Flow oauth log had this:
{"module":"flow-oauth","timestamp":"2025-11-25T01:09:33.307Z","level":"info","message":"inbound : Connection Failed: {"code":"ECONNREFUSED"}"}None of the logs were very direct in indicating exactly what was wrong and the connection failed was difficult to track down because I could access everything via browser/curl.
In the end, it turned out that I messed up the orchestration.crt by following the instructions to generate those by hand instead of copying what was already there for Foundation.
