For Each loop in ThingWorx
ranjank
Hi Team,
Could somebody help me with the snippet alongwith example that how to write ForEach loop of JS in ThingWorx.
Suppose my array is var fruits = ["apple""orange""cherry"]; , then how to print each element (or access each element) of this array.
Thanks in advance.
6 REPLIES 6
Hello @ranjank ,
Can you try using
for (i = 0; i < fruits.length; i++) {
result = fruits[i];
Hope it helps,
Hi @Ciprian-Traian
It is a normal For Loop and I am looking for For Each loop.
The array which I have mentioned is just an example.
Please advise.
lbisax
(To:ranjank)
for your example the forEach synthax would be:
fruits.forEach (element => {
      // execute stuff for element
Hello @ranjank
The forEach() method calls a function once for each element in an array, in order.
To use foreach you should use something like.
var sum=0;
var numbers = [1234];
numbers.forEach(myFunction);
function myFunction(item) {
  sum += item;
Om Dukiya
What should be the output basetype to get the result of this for loop.
Help me in (abineshabd17@gmail.com)
Abinesh Loganathan
slangley
(To:ranjank)
Hi @ranjank.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
