Any side effects in giving force edit to the entities ??(except loosing updated datas)
Hi @AP_9587236
Can you confirm which product this is? If ThingWorx, please provide more details.
Regards.
--Sharon
Yes it is in thingworx. I want to learn more about force edit functionality. Like its behaviour and where and all it gets affected?
Hi @AP_9587236 ,
In ThingWorx composer, If you try to access the entity which is in edit mode by other user, force edit window will popup. There will be chances of loosing data saved by another user if you try to click on force edit. Best practice is to avoid force edit for the multiple user during development process.
Hope it Helps !!
So I guess Apart from loosing data, there is no other side effects of giving force edit. Thanks
Hi @AP_9587236
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
