Full permissions in sandbox project, no permissions in all other projects
SM_9588025
6-Contributor
Did you find any solution for this ?
2 REPLIES 2
Yes and no. I am not completely where I wanted to be but fairly close.
  • I created a project and assigned full permissions for my new colleague.
  • One important lesson I learned was to also assign permissions on Collections (Things, Thing Templates, Mashups, etc.) so he is allowed to create those entities.
  • I have also assigned design time permissions on EntityServices Resource but I am not 100% sure if that was necessary.
That's on top of my head, I may have missed something since it's a while ago.
Hope it helps
Benny
slangley
23-Emerald II
(To:BennyB)
Hi @SM_9588025.
For something like this, you may want to consider setting up a separate Sandbox instance that the new colleague can play with without having to worry about stepping on another user.  He could also install it locally on his machine if he's running the right configuration.  You would need to refer to the System Requirements to validate.  Note that even though Windows 10 is not listed, many of us run ThingWorx locally on our machines under this OS.  We're suggesting this as an option as the server you're referring to may be one that requires more restrictions to prevent contaminating existing data and projects.
--Sharon
