Hi everyone!
I'm using progress gauge and gauge widget in my dashboard.
I would like to know if someone has other type of gauge widget
I already searched in the marketplace but only found the progress gauge.
Regards.
Leonardo
The mentioned gauges by you are the only ones out-of-the-box available in PTC.
Maybe other customers have custom gauges but I am not aware of any of that.
Best regards,
Raluca Edu
Best regards,
Raluca Edu
Hi @einsfeldleo.
If the response provided by @raluca_edu answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
Hi @slangley
I will follow the answer from @raluca_edu and try find it with other customers because the progress gauge default from ThingWorx Foundation is not working yet.
Regards
Leonardo
