Hi All
I have successfully created regions on a Google Maps widget and they display correctly. However there is no way of knowing which region is which (for identification). The solution for this I believe is a "RegionTooltipField" which ThingWorx currently has however I have these current properties and the tooltip is not showing at runtime when I hover my cursor over a region:
If anyone can give me any advice on how to get a tooltip to show up for the regions (without the need for a tooltip mashup) I would highly appreciate it.
Many Thanks
You can add the field Name in the DataShape of the infotable propertie binded to RegionData. The field Name is at the same level as the infotable of infotable of locations. Then Name can be selected in RegionTooltipField1.
Case related: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS225480
